Th400 Temp Sending Unit?'s
Old 08-29-2007, 03:26 PM
XpEdItIoUs's Avatar
Default Th400 Temp Sending Unit?'s
Where are you guys taping for the temperature gauge sending unit? Besides the tans pan... I found a threaded hole on the drivers side of the trans case, Has anyone used that before?
Old 08-29-2007, 03:38 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
you could use a "t" on the line going out to the cooler since the oil in the pan will be lower than the fluid running trough the trans.
Old 08-29-2007, 03:46 PM
XpEdItIoUs's Avatar
any links?
Old 08-29-2007, 03:53 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
any links?
not on my computer.
Old 08-29-2007, 03:56 PM
XpEdItIoUs's Avatar
Is that what you are doing?
Old 08-29-2007, 04:01 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
in all honesty i haven't thought about buying one.
I have a trans cooler that totally enclosed in a case, the case gets filled with ice+water before the run, i don't think trans temps will be a problem for me.
Old 08-29-2007, 04:08 PM
XpEdItIoUs's Avatar
Wow Crazy are you going to fab that up?
Old 08-29-2007, 04:09 PM
XpEdItIoUs's Avatar
NVM i see that picture now, Thats what i would do if i was builing a race car.
Old 08-29-2007, 04:11 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
My PG case has 4 ports on the case 2 labeled out, 1 in, and one with nothing but i have an aftermarket case.
My pan also has a port.... maybe performabuilt will chime in when they see this to help out some more.
Old 08-29-2007, 08:05 PM
Pathological Modifier
Ryan K's Avatar
I just pulled the plug on the side and threaded the temp sensor into it. Thats the way I had my 4L60e... Hope it works fine.
