Transmission Shot?
Old 09-01-2007, 05:37 PM
99WS-6's Avatar
Default Transmission Shot?
Alright so this is what my car does. from a stand still full gas first gear revs out at 6500 drops down to 5500 goes back to 6000 and shifts into the next gear. from rolen start full gas down my rpms shoot all the way up to redline and it shifts durring this proccess i am getting no power to the wheels it is as if i am not in gear untill it red lines and shifts to the next gear. please some one have some answers for me
Old 09-01-2007, 05:39 PM
99WS-6's Avatar
i am leaven at this time i test it out again see whats going on idk this sounds very bad to me.
Old 09-01-2007, 06:16 PM
99WS-6's Avatar
alright well i am back from the drive this is what its doing.
From a stand still 1st gear auto transmission excelerates to 6500rpms
i seem to hit rev limiter drops down to 5500rpms
goes back up to 6000rpms shifts into second
third seems to be smooth
didnt have long enough stretch to hit 4th
alright from a role in4th gear about 40mph
hit the gas all the way down
seem to have power to the rear wheels for about 1k rpms
than its like a rubber band i seem to have no power at all for the rest of that gear rpms shoot way up to to 6500 and it drops back down to 5500 than back to 6000 and shifts to next gear than that is where i slingshot.
i read in the manual that when u press gas in all the way it automaticly down shifts the a lower gear. could something be going wrong with this please some help. starten to think there is no activity in this forum ever. i never get response to any of my threads any help would be great thank you
Old 09-01-2007, 07:25 PM
A502slo's Avatar
Call Frank at Performabuilt good guys and great trans. Will work with till your happy.
Old 09-01-2007, 07:42 PM
FLT
FLT's Avatar
I'm confused by reading your post. Does your trans seem to be slipping in second gear? Or does it just seem like you have a loss in power?
Old 09-01-2007, 07:49 PM
LS1Tech Sponsor
performabuilt's Avatar
While its possible you have some issue with the trans it really sounds more like maybe some control issue tuning etc. I would check and see what the fluid looks lik but those are odd symptoms
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 09-01-2007, 08:59 PM
99WS-6's Avatar
yes it seems to be slipping in second gear
Old 09-01-2007, 09:00 PM
99WS-6's Avatar
i will check fluids first thing in the morning wat should i be looking for?
if you listen close to the link in my profile for exhaust as u listen to me accelerate away u can kinda hear my first gear hesitate shifting outa first gear like i had mentioned
Old 09-01-2007, 09:28 PM
LS1Tech Sponsor
Well basically you are looking to see if its brown and dirty. If it is then I would pull the pan and see whats in there, If theres alot of grayish sludge then I would plan on getting a trans.
__________________
Call 888-744-6542
