will any 3200 stall do?
Old 09-06-2007, 02:02 PM
redgto4u's Avatar
Default will any 3200 stall do?
I'm looking for a torque converter in the range of 2800-3400 stall range. Will I need a special converter for my gto with a 150 shot and cam? I don't plan on locking it at wot so I won't need a multi-disk clutch in it...
Old 09-06-2007, 02:48 PM
LS1Tech Sponsor
performabuilt's Avatar
Well each manufacturer has different chracteristics . I know ours will handle that and Im sure most other sponsors here should handle that also.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 09-07-2007, 10:22 AM
Blacker's Avatar
You will need a converter that is specifically designed to take the abuse from N20.
Old 09-07-2007, 02:10 PM
koolaid_kid's Avatar
Get one that is not designed to handle that sudden shot and you will be examining the rear seal of your crankshaft again.
Old 09-07-2007, 09:48 PM
redgto4u's Avatar
will a vig 3200 be healthy enough or is a yank nitrous converter the only thing Icould put in there reliably/safely?
