Tranny cooler lines..size/how to
Old 09-11-2007, 12:06 AM
BOA279's Avatar
Default Tranny cooler lines..size/how to
can someone tell me the diameter of the tranny cooler lines and what type of connection they use? Im trying to figure out a way to bypass the stock cooler to a high proformance one using AN fittings and braided lines. I don't have the car atm so I can't look for myself. Should I just cut the original lines and swedge? Should I just run braided hose the whole way? Can the original line ends be purchased seperatly? thanks!!
Old 09-12-2007, 07:00 PM
lethal93ta's Avatar
I used EAR-991946ERL in the trans that 1/2 to -6 an I just have caps on the trans right now since I didnt get it in the car yet
Old 09-12-2007, 11:38 PM
BOA279's Avatar
sweet. So its 1/2 NPT...helps a lot
Old 09-13-2007, 03:18 AM
lethal93ta's Avatar
its not NPT its a straight cut thread. some guys use NPT but if you go to tight it will crack the case.
Old 09-13-2007, 06:43 AM
DanZ28's Avatar
I'm using 1/2" NPT to -6 AN fittings, as it came from rossler that way. You are right though, you do the magilla garilla turn on NPT fittings no matter what App, you can crack the case...
Dan
Old 05-23-2009, 01:19 PM
tording99Z28's Avatar
Bringing this one back from the dead, so how do you know how tight to go if you use 1/2 NPT fittings? Do you use any kind of teflon tape or sealant on them?
Old 05-23-2009, 09:43 PM
forcd ind's Avatar
do the right thing and get the right parts
http://www.purechoicemotorsports.com...cat/cat135.htm
Old 05-23-2009, 11:10 PM
FLT
FLT's Avatar
I think the above info on the 1/2 pipe should be 1/4 pipe. As mentioned in the thread the threads are a bit different so be careful if you use these. Vince
Old 05-23-2009, 11:19 PM
WE TODD DID's Avatar
For the record, I haven't had any troubles using a pipe thread fitting into a straight hole. That being said, the next one I do will probably crack.
I think as long as the fittings aren't overly tight, they will be fine, unless the case is stressed.
Old 05-23-2009, 11:34 PM
FLT
FLT's Avatar
Those are a great idea providing you have room in your vehicle in the tunnel area. I do not believe they will work for the rear fitting on a 99^ 4l80e in a fbody with out the use of a BFH! Thanks for the link. I have used the ones for -6 AN to 5/16 inverted on a couple of 400's and 350's using the factory fittings. Good info. Vince
Old 05-23-2009, 11:43 PM
So then the fittings I need are a 1/4" straight thread not 1/2" straight thread?
Old 05-24-2009, 12:26 AM
FLT
FLT's Avatar
Yes that is correct. Vince
Old 05-24-2009, 12:30 AM
DanZ28's Avatar
I think Vince is right, should be 1/4" pipe thread not 1/2" pipe like I said earlier in the thread.
Edit: vince just beat me to it .
Old 05-24-2009, 06:39 AM
forcd ind's Avatar
they are 1/4-18 STRAIGHT thread (i think they call them NPTS)
i dont believe in CROSS threading reg pipe fittings in them, but then i have seen some vise grips used on bolts also, lol
for the rear fitting to clear my tunnel, i used the stock fitting, marked where it would point to the front when tight, then trimmed it down, used a 90 deg #6 to 1/4 pipe (steel) fitting and trimmed down the pipe end, tig welded the 2 fittings together, ended up with a short fitting-GM didnt do a lot of favors putting that fitting back there, but in a truck it had a lot of room, lol
Old 05-24-2009, 06:51 PM
DanZ28's Avatar
Straight thread is in a 4L60? Could of swore my TH400 had pipe but now IDK.
Old 05-25-2009, 08:42 AM
tee-boy's Avatar
I just went to a transmission shop and the guy gave me the brass fittings (straight thread not tapered) for a 400 trans (didn't go AN b/c I'm cheap). If you go this way, don't overtighten (brass into aluminum). The transmission guy told me to use Permatex Grey Silicone on the threads for sealant or else risk cracking the case. I put a 5/16" tube nut from O'Reilly and a double flare on the 5/16" tubing.
Did the cooler, lines, fittings for under 50 bucks this way. Beats the heck out of quick disconnect, braided hose, and AN fittings, in my opinion, as it would have been more than triple the cost.
Now hopefully the case won't crack.
Old 05-26-2009, 08:43 PM
So I went today to my local hose shop and got some 1/4" NPT barbed fittings. The 1/4" NPT male side I will thread into the trans and then the barbed side I will put my hose for my cooler on and clamp it down with a clamp. This should work correct? I will not thread the NPT fitting in very tight and I will put some thread sealant on it also.
Old 03-20-2017, 12:40 PM
1hotroc's Avatar
thank you for this link! This place set me up with the correct fittings and knew exactly what I needed to run a aftermarket trans cooler bypassing radiator cooler while still retaining the factory trans cooler lines.
Running -6 braided line all the way to
the trans is a waste of time in my opinion.
Old 03-20-2017, 12:55 PM
01ssreda4's Avatar
Heres a thread also
https://ls1tech.com/forums/automatic...oler-line.html
Quick Reply: Tranny cooler lines..size/how to
