M6 to TH350 (speedo question)
I did a search and didnt find the info I'm looking for (read the sticky as well).
I have completed the swap with the exception of the SpeedO, is there an adaptor that I can buy for this?
edit - this is a 94 Z28
TIA
TIA
As far as I know the only way to retain your CC and ABS is to convery the tail shaft to use an electric sender, you can get the VDO converter but that will only run your speedo, thats what I finally believed to be true after many days of research and talking to a few people at VDO as well as the guys over at jagsthatrun.com about their converterwitch are basicly the exact same thing as the VDO sender with a different name on it.
