best cooling transmission oil pan
Derale #14104 700R4 / 4L60E Transmission Pan Cooler. This pan has turbulator cooling tubes using air flow beneath the vehicle to reduce the transmission fluid temperature from 20° to 50° F. Fluid capacity is increased by 2 quarts. This pan is 4" deep and has a drain plug. The pan gasket is included. Will not fit applications with OEM deep pans. Cost $94.00
