TransGo 4L60E-S and HD-3 MVB ?'s
Old 09-22-2007, 01:56 AM
Brad-Man's Avatar
Default TransGo 4L60E-S and HD-3 MVB ?'s
First - besides the video, is there any difference between the two kits? (if so what?)
Second - do the kits allow full engine braking instead of freewheeling when coasting? This is important because I live near mountains....
Thanks,
Brad
Old 09-22-2007, 03:22 AM
PBA
PBA's Avatar
All manual valve body kits from TransGo have engine braking. What is it you want to do here exactly?
Old 09-22-2007, 03:51 PM
Brad-Man's Avatar
I have an '83 280ZX Turbo that my friend and I have developed an adaptor kit for.
I intend to use a 4L60e that I picked up for a song (stock rebuild), with a 9.5" converter with appropriate stall speed to utilize in the car.
The engine is built to develop ~400 lb/ft of torque at 3600 rpm and ~375 HP.
The car will be a daily driver (converting from manual - bad left hip and ankle from an accident) so don't mind shifting per se, just having to work a clutch that can handle the power.
Old 09-23-2007, 05:56 AM
PBA
PBA's Avatar
What year is the transmission you plan to install? Are you using a computer to operate the transmission?
Quick Reply: TransGo 4L60E-S and HD-3 MVB ?'s
