How do you install the dipstick tube w engine in the car???
This damn thing is driving me crazy. I have tried to maneuver it every which way to get it to slide into the tranny with no luck. Has anyone ever had this problem before? If so how do you fix it?
Thanks in advance to anyone that stops me from throwing a hissy-girly fit.
You can try to unbolt the cross member and lowering the trans and see if that helps. I got my madman tube in that way but the stock one is longer and not sure if it will fit up in there with the passenger head on and the tranny installed.
Dan
Dan
Just did it last week. unbolt the four bolts holding the tranny crossmember. Using a jack, lower the tranny as far as it will go....once its started, have someone at the top TWIST the tube back and forth as you pull it into the hole from the bottom. It will slide in really easy when you twist it.
Make sure you replace the rubber gromet, or at least make sure it is in there before you put the tube in. All that should have to be done is remove the crossmember and lower tranny. Thats how I did mine.
Lane
Lane
