need asap help th400 or 4l80
Old 09-28-2007, 05:01 PM
ls1sleeper's Avatar
Default need asap help th400 or 4l80
i blew my trans in my 2000 T/A, i hvae about 520rwhp i can get a 4l80 for cheap or a turbo 400 for a good price that is built up, whats should i do, im putting a 4200 stall in it,
4l80e is it strong enough stock or should i go with th400?
please i drag race the car an drive it, need assistance trans is out my car already need a direction as what i should do my car cannot be down for every!!!
Old 09-28-2007, 10:27 PM
98turbls1's Avatar
FWIW a 4L80 is basically a TH400 with overdrive... They are quite a bit more expensive to build and I believe that you need some sort of electronics (BS3 or a standalone box) to control it... Either one with hold quite a bit of power...
Old 09-28-2007, 10:31 PM
Bad30th's Avatar
You can control a 4L80E with a tune change, I did mine with HPT and control it with the stock PCM.
I highly recommend the swap - just be aware if you're swapping from a 4L60E you will lose a little power with the swap but gain a lot more durability.
Rob (Bad30th)
Old 09-29-2007, 02:18 AM
ls1sleeper's Avatar
well im putting a th400 in it i think i just need to find out how to make my shifter work with the rmvb
Old 09-29-2007, 03:13 AM
Strahley's Avatar
Get a ratchet shifter from B&M or Hurst or something. You'll need one for a RMVB
Old 09-29-2007, 06:53 AM
Race your car!
JL ws-6's Avatar
get the 4l80 and have it built with a manual valve body, it will be a TON of fun and ou'll have the overdrive for highway cruising.
Old 09-29-2007, 07:44 AM
408z28's Avatar
You can use your stock shifter, the shifter dosent know what trans its on, its just a lever that pulls the cable. You can get a P-R-N-1-2-3 decal made for the console cover that would look factory. Thats what I was going to do when I had my th400... I just decided to go 4l80e instead (I wanted OD)
