what everyone shifting at with yank pe 4200
Old 10-08-2007, 09:46 AM
DarkDemon's Avatar
Default what everyone shifting at with yank pe 4200
Ever since i've had it tranny won't shift at wot. Maybe it needs more rpms is what i'm thinking but i don't know. Shifts have been anywhere from 6000-6400.
Old 10-08-2007, 10:35 AM
Omega Doom's Avatar
have you had it tuned yet? I have the same Yank 4200 and it stutters at WOT between shifts but was told it's because it's not tuned as of yet!
Old 10-08-2007, 10:39 AM
DarkDemon's Avatar
yeah i recently had it tuned locally
Old 10-08-2007, 11:01 AM
Custm2500's #1 Fan
silver-mod-o's Avatar
is it flaring through the shift and hitting the limiter?
Old 10-08-2007, 11:31 AM
DarkDemon's Avatar
no flaring, just hits the limiter
Old 10-08-2007, 12:50 PM
Omega Doom's Avatar
sounds like the tune is off somewhere in the shift point's? have it checked out and retuned?
Old 10-08-2007, 01:30 PM
DarkDemon's Avatar
yeah might have to do that, thanks
Old 10-08-2007, 01:44 PM
Omega Doom's Avatar
what year is your car? mine is a 2002 WS6 silver A4 with a Yank PE 4200!
Old 10-08-2007, 01:53 PM
DarkDemon's Avatar
1998
Old 10-08-2007, 02:33 PM
camaro98z28's Avatar
Mine is doing the same thing. Hitting the limiter. Its a built tranny to. It has to be the tune.
Old 10-08-2007, 02:49 PM
DarkDemon's Avatar
yeah i'm thinking the same, cuz mine was built just a couple of months ago. And its done it since day 1.
Old 10-08-2007, 03:31 PM
Jordan S.'s Avatar
Tune. That a big converter for only shifting at 6000.
Old 10-08-2007, 03:36 PM
DarkDemon's Avatar
so what u think 6800 shifts?
maybe i should throw out the setup. 408ci, afr 225 heads, ported fast 90/90, 244/249 cam, bolt-ons, ect.
Old 10-08-2007, 03:53 PM
MIne does it only when going from 1-2 and 2-3 at WOT. I'm not sure what tune it has. I might have to ask NIC D again. I think he sent me the tune via e mail so I will have to download it but the only problem is, my laptop only has USB and HPTUNER is serial port. Not sure how to make it work.
Old 10-08-2007, 04:18 PM
Omega Doom's Avatar
oh wow! I have a stock block,heads,cam,intake,TB LS1 with only mods being a lid,FLP long tubes,Hutto 3" true duals with bullet mufflers and of course the Yank PE 4200!
Old 10-08-2007, 04:22 PM
HaulinHawk's Avatar
x2!!! I am shiftin at 6800 on my cam only setup.I would think with your setup you would be around the same,what rpm does your setup peak at?
Old 10-08-2007, 04:26 PM
DarkDemon's Avatar
not sure maybe i should hit a dyno or talk to patrick g (speced cam)
