94 camaro 4l60e tranny problems
Old 10-11-2007, 09:24 PM
comptonz28's Avatar
Default 94 camaro 4l60e tranny problems
i have a 94 camaro auto, my problem is when i get on the gas. more than half throttle it will be fine through 1st gear and when it goes to shift into 2nd it will just rev. it dont engage. but say im driving down the highway and it is in overdrive and i kick it down into third it is fine. only when it goes to second it slips.
what could this be?
Old 10-11-2007, 09:33 PM
LS1Tech Sponsor
performabuilt's Avatar
There maybe some issue with the 2nd accum piston/spring or the band how many miles are on the car and what does the fluid look/smell like?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 10-11-2007, 10:05 PM
LS1Tech Sponsor
performabuilt2's Avatar
taste like?
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old 10-11-2007, 10:07 PM
comptonz28's Avatar
107k. fluid is a very light brownish color. has no red tint to it. i thought that maybe changing the fluid would help. as far as smell it really dont smell burnt or anything.
Old 10-11-2007, 10:08 PM
comptonz28's Avatar
Originally Posted by performabuilt2
taste like?
kinda like cherry cheesecake
Old 10-11-2007, 10:15 PM
LS1Tech Sponsor
I would pull the pan and change the filter while in there not whats in the pan or take a pic and we can get a better idea, But 107k is alot particulary if its seen any performance driving.
oooh Cherry Cheesecake yummy! lol
__________________
Call 888-744-6542
Old 10-11-2007, 10:23 PM
comptonz28's Avatar
i have just attained this car but it has a hypertech programmer and it was set in performance mode. and i know the guy that had it before and he dont go slow anywhere.
would it be worth rebuilding? or should i do a 4l80e swap?
Old 10-11-2007, 10:30 PM
LS1Tech Sponsor
Well it depends on your power, unless your really xstreme on the power I would just order a well built Performance unit. . Now if you think your gonna have alotta power a 4L80E might be in line but its really exspensive swap.Consider that the 4L60E has gone 107k and is only now dying ?
__________________
Call 888-744-6542
Old 10-11-2007, 11:15 PM
comptonz28's Avatar
what years and car models will fit my car as far as the tranny? what will swap with little mods?
Old 10-11-2007, 11:25 PM
LS1Tech Sponsor
93 trucks and 94 all are unique, While any year from 93 to 97 4l60e could be made to work with some mods. I would suggest you get one made to go in your car, And if you talking low milelage used its a virtual impossibility.
__________________
Call 888-744-6542
Old 10-11-2007, 11:29 PM
comptonz28's Avatar
what type of modifications have to be made?
Old 10-11-2007, 11:33 PM
LS1Tech Sponsor
Well there are a couple different case styles in those years some would not acomodate your converter cover other would have to be cut to clear your exhaust or both. The electronics changed there are several ways to deal with this ranging valve body swaps to various valve body mods. To much to go into detail , I strongly suggest you find the right one for your car. Anything can be done as they say but that dosent mean it allways should be lol
__________________
Call 888-744-6542
Old 10-11-2007, 11:35 PM
FLT
FLT's Avatar
Frank you forgot the blue in this post. LOL I personally would make sure to get the correct unit for your car. I'm not a big fan of mismatching things just to make it work. Do it right the first time and be done. Feel free to give me a call if you are thinking about purchasing a trans for your car. I have the correct f-body 4FFD core with tail housing in stock waiting to be rebuilt. Let me know if I can be of help. Vince
Old 10-11-2007, 11:36 PM
comptonz28's Avatar
alright. i just need to get it to stop slipping under acceleration in second. its weird though cuz it drives normal at less than half throttle.
Old 10-11-2007, 11:40 PM
FLT
FLT's Avatar
Sounds like you are having a band failure and or a 1/2 accumulator issue.
Old 10-11-2007, 11:42 PM
LS1Tech Sponsor
You could try a service and a PCS (presure control solenoid) We also have the correct unit for your car. But like I said before I did anything I would drop the pan take a look and if minimal debris. Replace PCS and FILTER put in some new fluid and see what happens, If theres alotta crap in there order another trans and drive that one till it gets there.
(As Vince mentioned looking at the 2nd accum would be a good idea to)
(Vince I like Blue. Greens cool too BREAKS THINKS UP A BIT LOL)
__________________
Call 888-744-6542
Old 10-11-2007, 11:50 PM
comptonz28's Avatar
well i dont have a whole lot of money so i really dont know if i should change the fluid. if i do it could just fry the tranny quicker right? and what is a "PCS"
Old 10-11-2007, 11:52 PM
LS1Tech Sponsor
Presure control solenoid its in the pan and easy to change during a filter change and wether the fluid would help or hurt is anybodys guess I have seen it go both ways
__________________
Call 888-744-6542
Old 10-11-2007, 11:56 PM
comptonz28's Avatar
what does a pcs usually cost
Old 10-11-2007, 11:57 PM
LS1Tech Sponsor
It varies 40 to 70 dollars depending on where you get it ,
__________________
Call 888-744-6542
Quick Reply: 94 camaro 4l60e tranny problems
