Trany Slipping!!!
Trany Slipping!!!
Quick question. My tran. is slipping and its only on wot, i checked the trans fluid and it looked nothing like trans fluid it had a brownish look. So i wanted to change the fluid and i went to a couple shops and they said they dont recommend it that by changing it i might just mess it up completely. So right now i im clueless. Any suggestions and opinions? Thanks.
Sory to see your unit go down, or going down. If you take it easy for the time being you can buy yourself some time to plan for the replacement if you have not done so already.
Give us a call if you would like to explore some options!
Good Luck with it.
g
Good Luck with it.
g
