has anyone heard of an A4 shifting 5 times
a4 shifting 5 gears either theirs a trick when u get your tranny built to where u dont need a converter and make it shift 5 times ...i dont know any help...
It is very likely that what you heard of or felt is the converter clutch locking up. Depending on the converter stall it will be more apparent. In a low stall setup it can and will feel like another gear has engaged. In a high stall converter setup it may not be noticeable.
We set our converter clutch lock up circuits to apply firmly, we don't like seeing converter clutches slipping and wiping out our units.
Hope that helps!
g
Hope that helps!
g
Hope that helps!
g
Hope that helps!
g
sounds like to me someone removed the ball and capsule from the input shaft and removed the tcc modulated apply which will make the lockup feel like a 5th gear
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
