th 350
th 350
ok i want to put a th 350 in my car
i will be using a umi tunnel mounted torque arm
pst drive shaft
what will i need as far as a crossmember and how long of a tail shaft do i need
pst drive shaft
LS1Tech Sponsor
With the long tail 9 inch 350 the stock length drive shaft will be fine . With the short tail 6 inch the shaft will need to be three inches longer. Not sure on cross memebr as I have never personally done this swap as I never thought it a great idea except for dragsters. But I hope the little info I have give is helpfull.
__________________
As for the crossmember I know BMR makes one but have not seen anything from UMI or Spohn. The BMR should run you about 180 dollars. Here is the link to the page for BMR: http://www.gnetworks.com/v4/go.gnf?s...¤tPage=3
