someone please help with my th400 please please please
Old 11-07-2007, 05:35 PM
Travose21's Avatar
Default someone please help with my th400 please please please
ok when i put the car into 1st gear it takes off shift to second and nothing happens and when it goes to third everything locks and the rear brakes just stop the tires from spinning. but when i put it back in first it goes like nothing is wrong. it dont shift to second but it shifts to third then it starts tripping.
Old 11-07-2007, 05:51 PM
Travose21's Avatar
i know someone has had this problem anyone. its like the car wont go in second gear but goes to third and then it kills the tranny it kinda hard to explain but it is like it is trying to go into park
Old 11-07-2007, 07:04 PM
ls1pwrdss's Avatar
i know i know
broke sprag
Old 11-07-2007, 07:20 PM
LS1Tech Sponsor
performabuilt's Avatar
Intermediate sprag would be the likley cause . I think I spoke to you on the phone
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-07-2007, 07:23 PM
Travose21's Avatar
yes that was me on the phone.
Old 11-07-2007, 07:33 PM
Travose21's Avatar
hope it is a broke sprag. if it is what sprag to go with
Old 11-07-2007, 07:42 PM
jakeshoe's Avatar
You need a borg warner 34 element sprag and an early TH400 drum or a 4L80-E drum.
I machine the common TH400 drums to use a sprag element so I can control the diameter of the race. Many of the early Th400 drums have been reground and are undersize allowing the sprag to roll easier.
Old 11-07-2007, 08:12 PM
FLT
FLT's Avatar
Intermediate sprag is your problem. The sprag is designed to free wheel in 3rd. Seeing as you have no 2nd when the sprag should be holding and a bind up in 3rd, it's pretty obvious. Builder error! Vince
Old 11-07-2007, 08:16 PM
jakeshoe's Avatar
Yes if it is a fresh install the builder def put the sprag in backwards. If it's a unit that was running it likely broke the sprag and its slipping in 2nd locking up in 3rd.
I installed a low sprag in a TH400 backwards ONCE. LOL Most are not sprag type and it was one of the first TH400s I ever did. Lesson learned.
Old 11-07-2007, 10:55 PM
ls1pwrdss's Avatar
good old tci trannys there travis
Old 11-08-2007, 06:24 AM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
when did it start doing this? i know i spoke to you on the phone before i went on vacation and you said it did great at the track.
this is not a fresh rebuild. i was running it when we traded.
what would cause it to fail?
Old 11-12-2007, 05:59 PM
Travose21's Avatar
it started doing this when I was driving in the city. no warning at all. it just did it out of the blue. how much will it cost to rebuild and what part should I buy. I need the best
Old 11-12-2007, 06:28 PM
red83's Avatar
i hate it happened. no more than what you got to drive it.
i read an article on another forum a while back that said.
if you do a burnout in 2nd gear do not let the tires catch in 2nd gear, be sure to shift into 3rd before the tires catch and gradually let off. i also remember reading something about not turning the car off while rolling also, but cant remember exactly what it said.
maybe the trans. gurus can chime in!
Old 11-12-2007, 07:01 PM
Gilbert@Ace Racing's Avatar
Based on the comments since Vinc offered his advice I would have to suggest that the sprag rolled. It is not likely, but I have seen stranger things. Usually they will fail outright before this happens.
The cost to repair it is going to be dictated by what needs to be done internally and whether you pay for someone to R&R it for you.
Typically we charge $275.00 plus parts for a bench repair on a well built "fresh" unit.. not a bench overhaul mind you. If it needs to be completely reconditioned it would be $450.00 plus parts in our shop.
If you would like to know more just give us a call tomorrow.
g
Old 11-13-2007, 08:47 PM
ls1pwrdss's Avatar
HEY TRAVIS GILBERT AT ACE is going to be building my tranny in my car.
i have talked extenisvly with this guy you know i would never stear you in the wrong direction. he knows his stuff and i think that would be best to get it done because i dont know of any reliable tranny builders here in new orleans that does good and offers a warranty.
Old 11-13-2007, 10:36 PM
I understand your frustration Travis... sometimes you just wanna punt!
If you would like some solid advice from someone who has been building 400's for well over 20 years, give us a call we would be happy to discuss this repair with you.
And not to worry, if you have another source for this repair and want a second opinion about which way to go or what to do let me know. Between John and I there is no doubt we will help you find the best route to go.
Thanks for the kind words Nick.
g
Old 11-13-2007, 11:14 PM
LS1Tech Sponsor
You may can change it yourself if you want to try it give me a yell and I will walk you through it
__________________
Call 888-744-6542
Old 11-13-2007, 11:40 PM
Travose21's Avatar
i cant change this myself. i the shop i was told to go to down here gonna charge me 875 plus tax with a 1 year warranty. is that high or a fair price. thats to drop it off and they do everything
Old 11-13-2007, 11:49 PM
LS1Tech Sponsor
Well actually you probably could change it yourself, However if the unit has just been built if you cant get the guy who built it to fix it I guess you have no choice, And with the R&I and figuring they are planing on more than just the sprag (intermediate clutch) and other contamination possible thats not to bad if they are going to warranty the whole trans for 1 year
__________________
Call 888-744-6542
Old 11-13-2007, 11:51 PM
Well at first glance it seems fair if it is a parts and labor quote.
But you need to know what you are getting for your money... ask them what parts they are going to install and let's go from there.
g
Quick Reply: someone please help with my th400 please please please
