m6 guy needs some a4 help
Old 11-11-2007, 10:19 AM
dave70's Avatar
Default m6 guy needs some a4 help
Two quick questions for you guys I installed a converter (3200 vig) into a friends car (02 hawk) LT's,ORY,125 dry shot. How large should i go with the cooler? As in core size? On the stock cooler in the radiator is the top line the inlet and bottom the outlet back to the trans or the other way around?
Thanks Guys!!!!
Old 11-11-2007, 10:36 AM
Gilbert@Ace Racing's Avatar
I wouldn't get so caught up in the idea of how large of a cooler to use, the fact that you are adding any auxillary cooler is going to be beneficial.
The bottom line on the transmission is the output to the cooler and of course the top line in the return.
g
Old 11-11-2007, 11:40 AM
dave70's Avatar
Thanks for the info i'll trace the lines from the trans to the cooler .
