Slack in the tranny?
Old 11-11-2007, 11:38 AM
kaos_'s Avatar
Default Slack in the tranny?
My 1-2 shift is usually really hard and the other shifts are randomly hard. Sometimes in good weather the shifts are very soft and almost unnoticeable. The tranny still feels fine but I can't stand the annoying clunk from the hard shifts. What is causing the clunk from the rear? My rearend also seems to be fine, with a recent fluid change and no signs of hard wear. What's the deal?
Old 11-11-2007, 11:47 AM
Gilbert@Ace Racing's Avatar
So the 1/2 shift is too firm?
Have you checked your mounts, u-joints and exhaust fitment?
Be sure to look at the torque arm mounts as well.
g
Old 11-11-2007, 11:55 AM
kaos_'s Avatar
the u-joints are brand new, brand new tranny mount. maybe it's the exhaust backfiring? but why would it do that? the exhaust doesn't move around at all. it's mounted pretty solid and gives no slack.
could a worn torque arm bushing cause a clunk?
Old 11-11-2007, 12:03 PM
Most definately! When you accelerate the nose of the rear axle tries to go up but the torque arm prevents that right? So then if the T.A. mounting bushing is worn then it will make all sorts of noises when shifting!
g
Old 11-11-2007, 12:04 PM
LS1Tech Sponsor
performabuilt's Avatar
Yes it would and is one of the most comon reasons for a clunck metalic sound i have run into
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-11-2007, 12:06 PM
kaos_'s Avatar
yeah, that is what i figured it would be. that bushing has a crapload of miles on it too so i'm sure it's cracked or something. i was thinking of just getting an energy suspension bushing until i can get a UMI adj torque arm. is there a better temporary alternative?
when replacing the bushing is there anything i need to watch out for to not ruin anything around it like load or pinion angle or something like that? and what are the torque specs and bit size I'm going to need?
thanks for your help guys!
Old 11-11-2007, 02:52 PM
If it is an original bushing, and the car is a '98... why not just install the factory mount. It will go in easier, it will last forever and it is probably much less expensive than the aftermarket part.
And it is pretty straight forward to install.
g
