Removing Console With Auto Trans?
Old 11-13-2007, 10:55 AM
Ronnie Abene's Avatar
Default Removing Console With Auto Trans?
How do you remove the shift *** on a 96 z28 with auto transmission? I have a repair manual that says you pry out a clip and the shift *** will come off the only trouble is I can"t see a clip anywhere on the shifter. Can anyone help? Thanks
Old 11-13-2007, 11:01 AM
dlove's Avatar
it is hidden on the back side (towards the radio) near the bottom of the ****
you will need a really small flat head
Old 11-13-2007, 12:07 PM
arcticwhiteTA's Avatar
I used a pair of needle nose pliers for it. Just be careful when putting it back in that it doesn't slip and go flying somewhere.... like mine did
Old 11-13-2007, 05:59 PM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
it looks like a big staple. like dlove said it is on the radio side of the ****. pull it back in 1st gear and you can see the clip. a real small flathead works good.
