TH350/TH400 Frequently Asked Questions
Old 06-12-2013, 08:49 PM
cliffdiver86's Avatar
Does anyone make a TH-400 swap kit?
Old 06-12-2013, 08:52 PM
1961ba427's Avatar
No, but Spohn makes a spacer to bolt between the stock T56 crossmember and the transmission mount so a TH400 will bolt up at the right driveline angle.
Old 06-12-2013, 09:07 PM
Wishful thinking haha. Thanks ill have to check it out
Old 06-14-2013, 08:58 AM
Back in the staging lane
Beeler422's Avatar
Originally Posted by dlove
Cooler lines-
TH400
Fitting Location Thread Size Flow Direction
Upper ¼" Pipe Return/in
Lower ¼" Pipe Cooler feed/out
I'm not sure about the TH350, but the fittings on the TH400 are a 1/4 in.-18 NPSM; not NPT. You can use an NPT but you run the risk of cracking the case. NPT is tapered where NPSM is not.
Old 09-09-2013, 12:09 AM
john.s's Avatar
Can't seem to really find a straight forward answer anywhere else but what about the throttle kick down on the TH350? Is it necessary?
Old 09-09-2013, 10:51 AM
93Z2871805's Avatar
No it's not, your trans just wont down-shift automatically, you'll have to manually pull it down a gear for passing.
Old 09-09-2013, 12:58 PM
john.s's Avatar
Ok thanks
Old 12-18-2013, 09:47 AM
N2Ojunky's Avatar
I have a 99 Z28 converted from a M6 to a th350 what do I need to get the speedometer and reverse lights working?
Old 01-20-2014, 10:38 AM
Beave's Avatar
Thanks for posting this info. Put a PTC th350 and converter in my car yesterday. Used a UMI crossmember and madman dipstick and everything else went together perfectly. Used the free speedo mod and it works perfect.
The following users liked this post:
INDWIND34 (01-17-2020)
Old 03-03-2014, 10:22 AM
1990gtcory's Avatar
Default Question
Have 6.0 flex plate turbo 400 what spacer and bolts needed please and thanks gm stuff
Old 03-03-2014, 11:31 AM
93Z2871805's Avatar
Spacer - 12563532
Bolts - 19257940
Old 03-03-2014, 08:23 PM
  #32
1961ba427's Avatar
Spacer - 12563532
Bolts - 19257940
Kenny, I can't remember whether the spacer goes between the flywheel and crank or between the flywheel and convertor??
I think it's between the flywheel and crank, but wouldn't that cause an issue with flywheel to starter engagement?
Old 03-03-2014, 09:59 PM
  #33
93Z2871805's Avatar
If it's a flat flexplate it goes between the flexplate and the converter, if it's a curved flexplate it goes between the flexplate and the crank.
The spur gear is pretty long (probably 1"), you're spacing it .400" to the rear, so if the OEM spot was towards the front of the gear (which I believe it is), then you'd just be shifting it to the rearmost part of the gear. I had to shim my starter ~ .060" FWIW (I know it's not shimming in the same direction you're talking about, I'm just throwing it out there, lol).
Old 03-04-2014, 06:34 AM
  #34
1961ba427's Avatar
Thank you
Old 03-04-2014, 11:43 PM
  #35
93Z2871805's Avatar
No prob bud
Old 03-07-2014, 05:06 PM
  #36
93v8clone's Avatar
Only dipstick I can find is a td350400fm36 , not a td3350400fm36 like the thread states in the dipstick number . Is the number I found correct ?
Old 03-07-2014, 08:26 PM
  #37
93Z2871805's Avatar
Yes. It was just a typo, someone hit "3" twice.
You want TD350400FM36 if you don't need a locking type, and 1211144-36 if you need a locking style.
Old 03-09-2014, 08:40 PM
  #38
(SS)'s Avatar
Great info
I'm just getting started on my first m6 to th350 swap.I may have missed it,but i didn't see any tq converter bolt part number Preferably ARP.Let me know if i'm missing anything.
-Here is my parts list sofar-
ARP 244-2901 - ARP Pro Series Flexplate Bolt Kits
TCI Auto 399753 - TCI Flexplates
B&M 80688 - B&M QuickSilver Shifters
B&M 70274 - B&M SuperCooler Oil Coolers
Madman dipstic
-This is for braided steel lines and fittings-
Russell Performance 640520 - Russell Transmission Cooler Line Fittings
Aeroquip FCA0620 - Aeroquip AQP Stainless Steel Braided Hose
Aeroquip FBM5013 - Aeroquip AN to NPT Adapter Fittings
Aeroquip FBM4422 - Aeroquip Reusable Hose Ends
Aeroquip FBM4412 - Aeroquip Reusable Hose Ends
Old 03-09-2014, 08:57 PM
  #39
93Z2871805's Avatar
Originally Posted by (SS)
Great info
Madman dipstic
Those ARP bolts will not work if you are planning to use a converter that has a standard SBC/BBC pilot as you'll need to use a crank spacer.
EDIT: I see that TCI flexplate comes with a spacer, so the ARP 244-2901 bolts wont work.
Old 03-09-2014, 09:25 PM
  #40
(SS)'s Avatar
What are the correct bolts?
Quick Reply: TH350/TH400 Frequently Asked Questions
