foot brake!!!!!!!!
Old 12-04-2007, 09:59 PM
RIDINFILTHY's Avatar
Default foot brake!!!!!!!!
i can only foot brake my fuddle 3400 to 2000rpms than it will spin and i hear of others foot braking much higher with the same stall rpm , i dont know'
the str if that matters any help would be appreciated
Old 12-05-2007, 01:45 AM
Chevy_Truck_Man's Avatar
Press brake harder and get stickier tires.... then it will stall higher
Old 12-05-2007, 08:54 AM
Gilbert@Ace Racing's Avatar
Foot braking is very relative to the overall powertrain combination. If you do not have enough power to push the stall, or as mentioned you do not have stickies out back it will never get there.
Comparing one car to another is not the best way of determining the stall speed on a given converter.
g
Old 12-06-2007, 12:39 AM
i have stickies and the converter was built for my horsepower so they say!! and i cant get below a 1.7 60ft which pisses me off !!!!!!!!!!!!!!
Old 12-06-2007, 08:39 AM
What did Fuddle say when you called them?
g
Old 12-06-2007, 11:09 AM
LS1Tech Sponsor
performabuilt's Avatar
You should speak with Fuddle from what I see they are good about helping work out issues and trying to make people happy when they arise.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-06-2007, 11:43 AM
b4c346's Avatar
Default fuddle 3400
my fuddle 3400 will foot brake to around 2300-2500 with mt radials.the best 60 ft iv'e gotten was a 1.78 which is o.k. with stock suspension.car is a 2001 ls1 camaro with lid ,3400 fuddle and drag radials.runs 12.82 at 105 with 3.23 gears.the tranny shop said the 3400 was probally closer to a 3000 stall.i like it alot for a dd.anything more would have killed my fuel milage.
Old 12-09-2007, 05:34 PM
yeah the best 60ft i have gotten is a 1.73 and i actually dont drive it that much so i am thinking of going to a 4000 so i can get better 60ft. but i am not sure cause i will spray the car soon and i dont want to run out of gear since i have 3.90s???????????
fuddle said i should be in the 1.6s all day, and when i asked him he said i should flash the converter from and idle off the line for better launches so that is what i do but still cant get there , i dont have that much power and maybe that is the reason i am only putin down like 340 or so
Old 12-10-2007, 01:24 AM
slick1851's Avatar
Are people still having alot of problems with fuddles?
Old 12-10-2007, 08:05 PM
RearMountKing's Avatar
Not that I cant think of.. I think they resolved alot of their customer service issue problems.... But.... I could be wrong, but I believe that the stall speeds dont necc. mean what the converter will brake stall too.... I believe the 3600 is what it will flash too...
Old 12-10-2007, 08:53 PM
eric01ss's Avatar
**** my fuddle cut 1.6x's 60ft and ran a best of 7.55 in the 1/8th lol
Old 12-10-2007, 09:38 PM
Thats a pretty impressive 60ft.... What kinda rear do you have?
Old 12-11-2007, 06:54 AM
Greaseymec's Avatar
My best 60' on my Fuddle 3000 stall (2.1 str) is a 1.59. I've got a few suspension mods and a 9" with a Detroit locker, 3.89 gear. My tires are Hoosier QTPs 27x11.5x15. I'll be pulling the verter this month to send it in for a re-stall to 3600. Off the line I hold the rpm around 1200 and stand on it on the third yellow. Just a bit of daylight under the skinnes! My datta logs show my rpm around 2700 just before the MPH goes from "0" to "1". It would probably make it to the rated stall of 3000 if I was running the juce. (coming soon) If I can get it to stall to around 3300 all motor (after the re-stall), it still leaves me room for the spray. I've been running this converter for two years. Its just a bit tight, but very consistant!
Mec
Old 12-11-2007, 05:57 PM
yeah they are tight!!!!!!!!i wish i could cut those 60's
Old 12-11-2007, 06:03 PM
eric01ss's Avatar
stock 10bolt with 3.23s no joke
Old 12-11-2007, 10:56 PM
SSkillz's Avatar
I was doing 1.6x's 60ft too with a pt4400 on a stock 10 bolt! Also had no problems with dd it just got to get used to it.
Old 12-12-2007, 10:39 PM
tkimrey's Avatar
My fuddle 3500 will foot brake all the way to 3500 on the street with street tires, if that helps any.
