4L60E Vent Tube
Old 12-17-2007, 12:13 PM
loyolacub68's Avatar
Default 4L60E Vent Tube
Hey guys,
I was doing a torque arm swap the other day and in removing the old arm I accidentally yanked a rubber hose off the tranny. Since then I have searched around and discovered that this is a vent tube for the tranny in case of overfilling and things like that. My question is, I yanked off the tube and the little check valve as well . Is it necessary to put the valve and hose back on? If so, does anyone have a picture of where it goes because I could not find out where to put the thing. Any help is greatly appreciated.
Old 12-17-2007, 02:08 PM
00Formula00's Avatar
I am swapping trans, and I put the vent tube back in, the only thing I was wondering was wat the T-Shaped piece on it is and where it goes...
Old 12-17-2007, 02:15 PM
I thought the T shaped piece was the check valve?? Hopefully someone will chime in with a picture or know exactly how it goes in.
Old 12-17-2007, 02:22 PM
I'll a pic. give me a sec.
Old 12-17-2007, 03:04 PM
Here you go.... It goes on the "crooked tube thingy"
Old 12-17-2007, 03:51 PM
Ah ha. So it is up close to the front. I guess its good to have on there so tranny oil would not get onto any of the exhaust parts. Thanks for the pic.
Old 12-17-2007, 06:28 PM
yup, let me know if you want anyting else...
Old 12-17-2007, 10:12 PM
382ssz28's Avatar
This is the breather hose and installed straight and then bent at the factory. The rubber hose is to keep the trans atf from spraying onto the catalytic converter which can reach temps in excess of 1200 degrees F. We have seen a number of cars and trucks at our shop that have caught fire so I would strongly suggest to put the hose on even though you may have removed the converter. Nice pictures quick.
Quick Reply: 4L60E Vent Tube
