hooking up spedo for th400
Can somebody tell me where to get the parts to make my speedo work. My car was a 4l60e and now has a th400 it is mainly a drag car that has strange brakes on all four corners so the wss and abs are long gone. What do i need and where can i get it?
I was waiting for a sponsor to offer the parts.
Go to the link above and follow that. Some incorrect info in the link--a sensor out of a 4L60E/700R4 will not work, they are 2" in diameter, a th400 is 1 7/8.
You could go to GM for the sensor and reluctor wheel. There are two reluctor wheels, one has a small ID for 27 spline outputs (1988-1990 2500 truck th400/3L80) or large ID wheel for 32 spline output shafts 1988-1990 3500 truck th400/3L80/3L80HD)
Your stock wire harness should plug right into the new sensor.
