avg trans temp for 4l60e
LS1Tech Sponsor
if your running through the stock radiator cooler and do not have a large aftermarket or any aux cooler generally just a little higher than engine temps with a stock converter. Considerably higher with high stall. But the lowest temperature attainable using only the stock cooler will be just above engine temperature, What temps are you getting ?
__________________
I have a vig 3600 and a 28k tranny cooler. I average 165-175 at the track in the heat of the summer. I haven't seen 180* yet. Someone correct me if I am wrong, but tranny fluids life span reduces after 190*. I have read that cottonseed oil, soybean oil, sun flower oil have been used as friction modifyers in transmission fluids. Burn these and the fluid breaks down quickly.
