Stainless steel braided hoses for tranny hose?
Has anybody here using them? If so please post some pictures. I'm trying to figure out everything to fix my leaky rubber tranny hose problem. Hose clamps aren't holding the pressure as a matter of fact I think it is also leaking at where the metal tubing transition to rubber hose.
Are you guys using ~AN fittings? I need direction so any help would be appreciated.
My experience is a bit different than grn95t/a in that the cars running the PushLock style fittings that I have been privy to have suffered leaks or catastrophic failures on hard passes.
I have plenty of experience with these type fittings in other apps., but have seen my fair share of them come apart on cooler lines. It is important to say that I have never relied on them for transmission cooler lines, therefore I have no 1st hand experience.
Just a word of caution. You do not want to have a cooler line rupture on a hard pass.... it can get ugly.
g
g
LS1Tech Sponsor
My experience is a bit different than grn95t/a in that the cars running the PushLock style fittings that I have been privy to have suffered leak or catastrophic failures on hard passes.
g
g
__________________
I was having the same problems with leaking rubber hoses and I got lucky when I purchased my TH400 in that it came with a B&M supercooler with AN fittings and braided lines. Looks great and zero leaks. The kit to do this is a bit pricey but well worth it.
I'm using Aeroquip FC332 push-on spec hose on my cooler lines without any issues.
It has a working temperature of up to 150'c, 250psi working pressure and 1000psi burst pressure.
Ive never measured the pressure on the cooler lines, but my understanding is that its the oil from the torque convertor, through the cooler and back to the pan - so the pressure isn't likely to be particulary high. It's not the mainline pressure (which can get up to around 250-270psi) as i understand it.
This stuff:
http://www.thinkauto.com/pushon1.htm
And that was also after seeing someones cooler line come loose on the strip, which wrecked the car.
HTH,
This stuff:
HTH,
g
g
i could see that happening if the wrong hose was being used.
g
g
This stuff:
HTH,
This stuff:
HTH,
What I do is call a call our local hydraulic hose co. and give them the specs for my current project. They in turn build hoses for the application using a high grade hydraulic hose and machine compressed hose ends and fittings.
In street apps... our technician Mike, simply cuts the existing steel lines where necessary and then flares the tubing and then completes the installation.
g
Moderator
I've had rubber hoses blow off the 'glide lines in my El Camino
but fixed that problem by using two worm glamps instead of
one. No leaks. No leaks on my cooler setup just using the
rubber hoses that came with, over the stock flares with hose
clamp. For better integrity you could get a flare to pipe and
pipe to barb, or maybe even turn up a flare to barb adaptor.
I have never had a rubber hose blow out (only off). So I think
braided stainless is only bling overkill for this, if you can get
the ends to hold tight.
