3500 stall?? tuning??
so I am planning on getting a 3500 stall...
How much tuning will I need to do for this..
most I am seeing is the shift points, tranny pressure??
what else.. if someone could shed a little light, I would be grateful..
thanks guys.
thanks guys.
You can drive it without a tune, but I do not recommend that.
They need to optimize your shift points, part throttle and WOT shifts. Tranny pressure, you could work with, personally I haven't. Are you doing gears with the stall?
I already have 3.73's in the car..
So basically I am putting the stall because I dont like the fact that I spin my tires at around 1100 RPM... That does not give me the ability to launch good..
Pretty much driving out of the hole.
My car is already tuned for the 3.73's
and I have tranny pressure adjusted, and shift points changed...
as well as RPM limiter.
I dropped a Yank 4200 stall and it drives fine but it does have issues? it will not shift at WOT on the 2-3 shift, and sometimes it just dies like 3-4 times in a row for no reason but then it act's OK? it will also come out of OD sometimes and after awhile or after you stop for a few minutes it will be fine? but it has got me to a 7.9@8? mph in the 1/8 with out the benefit of good traction and not shifting on the 2-3 shift before the finish line so I know I have something left in the TUNE!!!!
just a thought..
Vince says he has seen where the reverse idle might cause car to die with higher stall
he's right... my car does this. after putting my new tranny/stall in, my previous tune is now off a little bit. The car will try to die in reverse sometimes, and i also get some KR on each shift if i nail it from a stop. tune it.
