Turbo 350 Bellhousing Question??
Old 01-02-2008, 02:31 PM
CHEVYMAN434's Avatar
Default Turbo 350 Bellhousing Question??
I am doing a turbo 350 swap in my 02 ss.When i pulled the 4l60e it looked like it had alum. bolts in the bellhousing.I wanted to know if i should just reuse these bolts or get some grade 8 bolts.I was kinda worried about using a steel bolt in the alum.,but i just dont know i guess.Any help would be appreciated,thank you
Old 01-02-2008, 02:34 PM
dlove's Avatar
i would use the same. also you wont use all of them, only 5
