new vert with bad tranny
just picked up a 99 vert with a transmission problem for cheap. the problem is that it dosent go past 2nd gear. it shifts firm from first to second but thats as far as it goes. any advice or help would be appriciated. thanks guys
no not yet. i just picked it up a couple hrs. ago. i just wanna get an idea of what could be wrong before i bring it in. i'm no tranny expert so i dont want to get ripped lol!
LS1Tech Sponsor
Ok put on a scanner and see if its being commanded that would be the next step. if its is then there a problem with the trans likley. Then Once you have checked for codes and see that 3rd is being comanded. Unplug the harness plug from the trans , This should force third hear all the time except when in manual second or first in whch case it will start in second , But if in D or OD it should always be in 3rd gear.
__________________
i couldnt figure it out i had to bring it somewhere. they said if the tranny was bad it would cost about $2200 for a rebuild. i could probably buy another one for less than that!
Yep! A very well built unit would be less than the price you were quoted. of course I don't know what their build specs are... but I think yu're on the right track.
Give me a call if you are interested in replacing it. I'll be here another hour or so and then I will be in all day tomorrow as well.
g
g
