tranny fluid dye
Old 01-10-2008, 11:42 PM
Turbo V6 Camaro's Avatar
Default tranny fluid dye
is there anything i can do? i'm color blind an i cant read the fearking dip stick
is there anything i can put in there to at least darken it up so i can see the fluid level ?
Old 01-10-2008, 11:54 PM
LS1Tech Sponsor
performabuilt's Avatar
Well and oil based black dye may work dont think could hurt anything
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 01-11-2008, 12:41 AM
enos44's Avatar
my only idea would be to either have a friend read it or just run you finger down it until you feel the fluid then see where it is i dont know if id bother with dyes, my dad is color blind and i mean cant see any colors and what he does is pull it out then put it in the light or shine a bright light on it to see the reflection hope this helps.
Old 01-11-2008, 04:33 PM
thing is a friend is not always around !!!
i have tried that other methods with no luck i'm wrong every time
Old 01-13-2008, 06:09 PM
jxaxsxoxn's Avatar
How about pulling the stick and putting some powder on it? Seems like even baby powder would show enough to see a difference.
FWIW I got some super tech trans fluid at walmart, one gallon jug and it was almost clear, I could hardly see that on the stick.
