shift kits
Most guys will find that the HD-2 kit is very difficult to install. It really should be installed by professionals as complete dissasembly of the transmission is required if all of the components are going to be installed.
g
g
I have a "modified" version that works very well, without going into the transmission. The transmission has to be in good working order to start with, this kit is not going to save a transmission on the way out.
HD2-C with new seperator plate and billet accumulators.
Just order a new plate with it, the check ***** had nearly hammered their way through the plate plus it saves you time when you are actually installing the kit to the car.
Check out Trango' installation video. Absoloute gold. It will only help with getting the valvebody out and in. The shift kit is up to you.
http://transgo.com/video.php
