th400 specifications
Old 02-02-2008, 07:25 PM
ATAY383's Avatar
Question th400 specifications
Okay i have a chance to get a th400 and i talked to my friend and said its not worth it unless u have a thousand to spend cause u need new drive shaft and everything else. i dont believe that but i could be wrong cause i new it will bolt right up and u have to modify the drive shaft but could u guys tell me if my freind is wrong and tell me what i need to do to get it in my camaro.
Old 02-02-2008, 08:27 PM
fenix999's Avatar
u might eb able to use a 6 speed crossmember for that th400 tranny, but yea depending on the length of the model th400 you have, you will need a new driveshaft and need to do soemthing to get the speedometer to work. Its not really a big deal to get it to work and if you're smart about it and know what you're doing i dont think you will spend no where near $1000. Hope this helps
Old 02-03-2008, 03:18 AM
revtime's Avatar
Yeah 500 bucks will do the job and thats if you go the expensive route.
BMR conversion crossmember 250
shorten DS locally 100 150 bucks.
This is assuming a compatible converter comes with the TH400.
Here is my list of parts. Not including the TH400 and converter.
BMR conversion crossmember with TA relocation - 250
B&M SFI flexplate - 75
B&M Pro Stick shifter with RMVB gate plate - 150
My tranny came with a VSS already installed so it was plug and play for the speedo.
Dennys Nitrous ready driveshaft - 350
This is also assuming you doing all the work yourself.
I could not afford this hobby if I had to pay someone else to do my wrenching.
Quick Reply: th400 specifications
