Stock 4l60E pan depth?
Anyone happen know the depth of the stock tranny pan before I have to go lay on the wet ground to see. Looking for a new pan with a drain bolt,dont want it dragging on the ground.
Moderator
It's about 2" or so. Stay away from the TCI deep finned
one if you are lowered, that is a speed bump snag. I have
a truck pan off a '02 Silverado, maybe 1/2" deeper, which
I like so I can use the truck filter that is deeper in the
juice. It is not as low as my Y-pipe, so it's fine. I have
had poor luck with a chrome pan, for sealing. I think the
truck pan is the best, toughest option (steel dents,
aluminum cracks if you go "off-roading").
