Installed a Yank, but what's wrong?
Just got done installing a yank 4k for a th350, it feels extremely loose like I expected. But when I hit on the hwy where it won't spin, it revs right to 6500 but pulls but I don't see the tach move again, so I hit the rev limiter of course. Pulling back up to the house I come around a corner and it almost felt like the tranny slipped and then was fine. Any ideas what to check for?
Thanks
Thanks
When you install a TH350 in an F-body the dipstick will read incorrectly as to the angle of the trans the f-body engine is set up to have the crankshaft level and the orginal use of the TH350 was at a 5 deg downward angle so do not count on the dipstick for correct reading
Ok fluid looks and smells fine, level is good, hooked up the tach, shoots to 6k whenever I go full throttle. I'm not sure what else to check for other than something is wrong with the converter, trans was fine before with tight nitrous stall.
