Stall ? for th-400
Stall ? for th-400
Have a quick? .. I am still in the middle of my current build and my rear is still set up for the 6-speed i used to have, with 4.10's, Well i converted to RMVB TH-400. When i go to order this stall i know they want weight, cam specs, etc. Well what if i got the stall, and the 4.10 gear can get me threw the traps.. i have no way to test this till the motor and tranny is in the car... Well if i was do drop back to a 3.73 or 3.90 would this hurt what the converter was setup for? I am going to be ordering a custom converter.. Thanks also running a 28inch tire for the record
I got a 4.10 gear w/ a 347cu in and a 28" tire w/4000 stall, trap speeds are 125 on motor 1.56 60', 131 mph on 100shot w/1.50 60', in my other camaro with the 402 LS2, I also installed a 4.10 w/28" tire. I think your car should run good.
I Say 3.73. I Got A Th400 From Rosslers. Stock 3.42's 3000rpm At 60mph And 3600 Vig Stall. Havent Been To The Track With The Th400, But Too Much Gear Will Give You High Rmp At The End Of The 1/4. It Also Depens On Your Tire Size.
