how do trans lines lock in? help!!!
this is my first time installing an auto with these type of connectors with the little plastic round clips, how do they go on? I thought I had them on but I can easily pull the line out after I thought the clip was in place, it doesent seem like they will stay in place with pressure in them. its a 4l60 in a camaro
yeah, you need the clips that go on the fittings. If you look at the fittings you will see a a slot...the clips co into those slots and then you push the line in. This locks the lines into the fitting. Then just slide the plastic pieces over the clips
Here is a photo of one of our transmissions with the new fittings that we install. Look closely and you can see the clips. Why is it that you do not have the clips for your trans? Is this a new unit that did not come with them or are you doing a conversion? Here is a photo to help you out.
that looks like what I have, I dident look close enough to see if the clips are inside the holes, I dont know if ill be able to get a close enough look so see. am I maybe just not pushing them in hard enough to get them to lock in? once there in place how do you remove them?
with the e-clips on the fittings,push the trans lines on untill they snap.then use the plastic piece to protect them. when pulling the lines out you have to use a pick to remove the clips before pulling the lines out,then put the clips back on the fitting so that you do not loose them.
I have a short video clip of me putting the clip in and snapping the cooler line in place.
Was testing the new camera, somehow this 30 second video ended up at 32MB.
Anyone want to see it? I figure it might be too big.
Can you just put a wrench on those fittings and turn them out instead of messing with the clips or will that mess something up in the tranny? I am in the middle of my converter swap right now and I am having a hell of a time with those clips. I have been messing with them for over an hour and I can not get them out to get the lines out. What am I doing wrong?
