GOOODAMMIT!!!! tranny is slipping.
OK here what its doing. Its dragging the shifts, its like the converter is not holding the power this is a rebuilt unit also. Tranny fluid is great and was about a quart low refilled it and it still slips. This is on a stock ls1 with a 95 lt1 transmission. It ran fine for a week now this is it fk? Im let it sit over night going to see if it dose it again.
LS1Tech Sponsor
Good luck with it when you try again , Being low on fluid could have caused the slipping , The 4l60e dosent do well at all even a little low. Unfortunatley damaged may have been done while it was being driven low on fluid, Give me a call if you would like to talk about it and describe what its doing,
__________________
