does the 4l60E need a computer???
Old 02-25-2008, 10:31 AM
2001-M6-Z28's Avatar
Default does the 4l60E need a computer???
hi guys. well im in the process of deciding what tranny to use with my lt1 carb setup.its going into my 55 belair. since i dont have the computer anymore,if i put the 4l60E in will it be fine??? or do i need some type of computer to make it shift and work properly etc. ... sorry this is a noob question, im still new to the whole learning about cars. (but i sure can drive one) lol. thanks for any help. Michael
Old 02-25-2008, 10:48 AM
LS1Tech Sponsor
performabuilt's Avatar
Yes it does require a PCM to operate, I would suggest the 700R4 for what your trying to do .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-25-2008, 11:48 AM
Moderator
jimmyblue's Avatar
That or you need a tranny control unit like TCI makes.
But I think with the carb setup might as well just go
mechanical on the trans too. Lockup actuation is a
question though.
Old 02-26-2008, 11:58 AM
so if i were to buy a 700R4 it would work without a computer??? or what else would i need. thanks guys
Old 02-26-2008, 12:31 PM
LS1Tech Sponsor
you would not need a computer and lockup can be handled in several ways. You would need a TV cable suggest LOKAR for that
__________________
Call 888-744-6542
Old 02-26-2008, 12:37 PM
i searched but couldnt find anything. what exactly do you mean by i would need a tv cable LOKAR???? and what exactly is lockup???
Old 02-26-2008, 12:41 PM
LS1Tech Sponsor
Well lockup is a clutch in the converter that eliminate converter slip while cruising , We have solutions for that. As for the TV cable its a cable that goes to the carb that controls line presure and shift points with the 700r4. LOKAR is a company that makes cables for various OEM and retro situations like yours.
__________________
Call 888-744-6542
Old 02-26-2008, 12:45 PM
oh ok. sweet thanks. im gonna go ahead and put my 4l60E for sale and then i'll buying a 700r4. thanks. (you'll be hearing from me in a few weeks)
Old 02-26-2008, 12:48 PM
oh yea. on your website it says level one 7004R. is that a mistake??? or is the different from the 700R4?? thanks mike
Old 02-26-2008, 01:07 PM
LS1Tech Sponsor
Miss print I will fix it
Thanks
__________________
Call 888-744-6542
Old 03-02-2008, 10:53 PM
X88&94GT's Avatar
I have a similar situation. Considering options in my 1963 Chevy Biscayne ( Impala ) Wagon . I would love to do the LSx swap with the elec trans but dont knwo about the costs. Saw a video on V8TV of a guy with a carb'd 68 Camaro running a 4l60e with the padle shifters.
Not worth it or? I wont be going to paddle shifters imediately but like the idea of that option down the road. That and it seems I can buy a 4l80e and not have to worry about it handleing the power. Any advice would be great.
Old 03-16-2008, 12:12 PM
bluecamaroz28's Avatar
Will this be enough to run the 4L80E without PCM control?
TRG-4L80E-S
Old 03-16-2008, 12:43 PM
LS1Tech Sponsor
Yes it will, However if you want lockup you will have to make arangments for it also. What are you putting the 80e in ?
__________________
Call 888-744-6542
Old 03-16-2008, 02:19 PM
It will go behind an LS7 in a street/strip Camaro but it's not a DD. It's a weekend car.
So, how do I keep the lockup for some 4th gear cruising.
I will probably get a truck 4L80E, so, what spline is the rear shaft compared to 4L60E and what do I need to connect to my drive shaft?
Old 03-16-2008, 02:30 PM
PatrickF's Avatar
Correct me if I'm wrong, but if make your 4L60E a full manual valve body (I think its TransGo HD-3) then theres no need for a computer?
Old 05-07-2008, 03:17 PM
blazin's Avatar
Also wondering the same. I will have a 4L60e in a car that has the trans wiring but no pcm to control it. I have seem some of the controllers control the lockup with a toggle?
Old 02-20-2018, 10:22 AM
skylarkmike69's Avatar
will a 700r4 bolt up to a 96 lt1
Old 02-20-2018, 12:03 PM
Restricted User
JoeNova's Avatar
You just brought up a 10-year old thread to ask something you could've typed into Google and got an answer immediately.
Quick Reply: does the 4l60E need a computer???
