bellhousing question
Old 02-27-2008, 10:15 PM
jimish's Avatar
Default bellhousing question
Help. I need someone to measure a bellhousing for a 4L60e. I just bought a bellhousing from chevrolet. Part #24206953. Open the box and the number embossed on the bulge where the starter goes says 24206952. Depth of this bellhousing is 7". If anyone has a 4l60e they can measure, I nee to know the depth and part number before I go back to the dealer and give him hell.
Old 02-27-2008, 10:41 PM
LS1Tech Sponsor
performabuilt's Avatar
What is the bell for engine wise ? LS1?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-27-2008, 10:50 PM
jimish's Avatar
Yes its a ls1 from a corvette, as a matter of fact the entire drivetrain is '02 C5. Instaed of the torque tube I need to mate the trans to the engine. I am also looking for the shallowest (?) bellhousing.
Old 02-27-2008, 10:52 PM
FLT
FLT's Avatar
# on the box is the part #. # on the part is a production # not a part #. Just a heads up. I once took a # of a part and tried to order what I needed. The guy in parts said you do know that this is a $3000 engine? Whoops! Just a heads up. Vince
Old 02-27-2008, 10:59 PM
LS1Tech Sponsor
Ok you have a strange combination , You have and LS1 engine normally I would say you need a bell with a bolt dead center top but with the trans you have this is not the case you need the LT1 housing without the bolt dead center top, But theres more It will use the lt1 style converter and to bolt to the LS1 you will need a converter pilot to crank spacer adapter, So if you have a bell with no bolt hole dead center top thats correct and would be the most shallow available, But you will also need the spacer just like the one used for a TH350 OR 400 TO ls1 swap .
__________________
Call 888-744-6542
Old 02-27-2008, 11:12 PM
jimish's Avatar
Amazing you guys are both on. You can both disregard my e-mails regarding this as I'm getting my answers. Engine has a bolt dead center top, but none at 1:00 pass. side. Bellhousing (#...53) has 5 equal holes across the top. Do you know the chevy part # for the LT1, 6" bellhousing? Again, if I have that shorter bell, it looks like I can use my converter without 'extensions'.
Old 02-27-2008, 11:21 PM
LS1Tech Sponsor
We have plenty of those bells if you want to give me a call tomorrow
__________________
Call 888-744-6542
Old 02-27-2008, 11:31 PM
jimish's Avatar
Will do. Thanks
Old 02-28-2008, 05:31 PM
LS1Tech Sponsor
24206975 this is the number we found on our LT-1 style bolt on bell housings. This should be what you need .
__________________
Call 888-744-6542
Quick Reply: bellhousing question
