Locking Up The Converter Manually
I don't think the speedo is correct on my car. In fact I know it's off. I will check to see if it matters. What's the worst thing that will happen if you forget to unlock the converter if it was on a toggle switch? Thanks DeltaT
So what you're saying is that even though this trans will be fully manual, I should be able to get the converter to lock automatically? When will it lock? What will it use to determine when and when not to lock? I don't know jack s**t about automatics and I appreciate all the advice. Where will I find this software to load? Is it already in the HP Tuners? Thanks.
