Torlon check balls
Old 03-06-2008, 05:24 PM
chargedvx6's Avatar
Default Torlon check *****
What is Torlon? And what is the advantage if any in using Torlon check *****?
Old 03-06-2008, 05:45 PM
Gilbert@Ace Racing's Avatar
TorlonŽ polyamide-imide (PAI) has the highest strength and stiffness of any thermoplastic up to 275°C (525°F). It has outstanding resistance to wear, creep, and chemicals— including strong acids and most organics—and is ideally suited for severe service environments.
As taken from this website.... http://www.solvayadvancedpolymers.co...ogle&WT.srch=1
The reason for using those check ***** is that they are lighter and much less abusive than the Steel ***** used by the factory. It is not unusual for the steel ***** to hammer their way through the valve body plate over time.
Hope that helps.
g
Old 03-07-2008, 12:16 AM
chargedvx6's Avatar
Thanks, are they pricey?
Quick Reply: Torlon check balls
