what converter
Old 03-08-2008, 01:26 PM
UnderConstruction's Avatar
Default what converter
Mods are. Magic stick v3,afr205 heads,fast 90/90 combo, 150 to 250 wet shot, electric water pump,hooker headers,42lb racetronic injectors, forged 346 car has 3.73s I have a vig 4400 right now but im affraid I would run out of gear. I was going to have it restalled but trying to figure out what would be best for the set up. LMK and sorry for the dumb question
Old 03-08-2008, 01:34 PM
Gilbert@Ace Racing's Avatar
That's not a dumb question dude! It's actually very smart to ask IMHO.
A 250 shot is pretty healthy. In a 1/4 mile pass I would think that a 4400 stall would be pretty loose. In a 1/8 mile pass you might get away with it.
With that H/C combo it will want to make power low... I would recommend a stall in the 3,600 - 4,000 range. It really is going to depend on how quickly you bring in the N20.
Is this a DD car as well?
g
Old 03-08-2008, 01:38 PM
no its just mainly a show car and strip
Old 03-08-2008, 02:12 PM
crashinaz's Avatar
Well, the 4400 is fine for NA, but you're leaving A LOT of useful torque on the table on the spray. With a decent shot of n2o, you'll blow WAY through that converter.
Old 03-08-2008, 02:58 PM
Im thinking about having it restalled to a really tight 3800 i sent vig a e-mail will be calling monday so if anymore suggestions lmk
Old 03-08-2008, 03:01 PM
In all fairness I think 3800 might be high... but converters are very combination dependant. I do think you need a starting point and 3800 is as good a place as any to begin.
g
Old 03-08-2008, 05:41 PM
well ive been looking at 3600 as well
Old 03-09-2008, 11:33 AM
Yank's Avatar
With the 3.73 you might look at the PT4000 or at least a SS4000 the PT and SS will put more power to the ground that you current converter.
Old 03-09-2008, 01:00 PM
Captain InsaneO's Avatar
Since I have nitrous, I went with the Vig 4000 3 disc converter. You can lock the converter at WOT in 3rd, and never worry about spraying through the converter. If you want to know more call RPM Transmissions.
