What tranny for 850hp?
Basically have a 850hp n/a motor in a 25.2 car. We have had a A1 torque converter and a TCI in a TCI and a Rossler transmission. We just cant seem to get a good run in because we either break the converter or it wont stall up high enough. The TCI converter was suppose to be a 6500 but wont stall over 4000. A1 was a 6500 and ended up having metal shavings after 5 runs. We are spinning the motor to 8600rpm. What are some of the big hp guys running?
Both transmissions were built with the best we could get, light weight etc..... Car hits hard and just unloads before the 60ft.
EDIT: This car is a drag car 100%. The TCI and Rossler trannys we have been using were a TH400
