Shifting Problems?
Old 03-17-2008, 03:21 PM
mack's Avatar
Default Shifting Problems?
Just had a Pro Torque 3200 stall and had tranny rebuilt by CPT. Pro Race version. Problem is the car is shifting from 1st to second too soon under normal driving conditions. Can I change the mph of the shift point with hypertech?
95 T/A A-4
Old 03-17-2008, 03:54 PM
BOA279's Avatar
not sure about hypertech but definatly sounds like a tune issue to me.
Old 03-17-2008, 04:48 PM
LS1Tech Sponsor
performabuilt's Avatar
I am not sure what all you can change with the hypertech on a 95 , But you will have to make some tunng alteration to correct the issue as the 60e shift timing is totally dependant on the PCM. Did you change converters or something that would affect what the PCM sees?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-17-2008, 04:57 PM
mack's Avatar
Yes, from stock stall to 3200 and from stock tranny to pro race version built tranny.
Freaken car is totally different. Shifts are much crisper and it never stops pulling. The shift pionts are just off. It's going into 2nd at about 15 to 17 mph.
Old 03-17-2008, 04:59 PM
LS1Tech Sponsor
You need to be tuned for the converter, Once thats done all should be good,
__________________
Call 888-744-6542
