What should i get my yank 3600ss to lock up at???
Old 03-25-2008, 02:35 PM
th3brandon's Avatar
Default What should i get my yank 3600ss to lock up at???
Just what the title states????
i know it will be around 35-38 on stock tune but how will it be with the mods in my sig.... i dont have my car tuned for anything in my sig yet,still wating to get everything installed.
What mph do guys think would be the best?????
Old 03-25-2008, 02:43 PM
DrkPhx's Avatar
First you need to make sure the PCM is adjusted for the 3.73 gears. Generally the stock lockup points are too low for a big stall and can be bumped up by about 5 mph. However, the actual shift points are really dependent on your actual setup and driving habits/preferences.
Old 03-25-2008, 02:46 PM
th3brandon's Avatar
so u say go about 5mph more then the stock so about 41-44????
for a rough guess
Old 03-25-2008, 02:54 PM
GregWS6&z28's Avatar
ive tuned mine to only lock up in 4th, and at 40mph. this helps my cam from bucking some at low throttle and higher gear
Old 03-25-2008, 03:17 PM
DrkPhx's Avatar
Mine is similar (slightly higher), but the lockup mph varies by a couple of mph depending on the TPS %. I would think with a 3600 he should be able to still use 3rd gear lockup.
Old 03-25-2008, 03:19 PM
DrkPhx's Avatar
for a rough guess
Definitely a rough guess. Hopefully you have tuning software so you can drive and adjust to suit your needs. IMO that's the only way to get the shifting nailed down correctly.
Old 03-25-2008, 03:26 PM
JScamaro's Avatar
My converter had clutch chatter when it locked up at 38, 40, and currently 42 mph.
I've tried two different tuners and used three different mph's and I still have a little clutch chatter.
Old 03-26-2008, 04:11 AM
99DWPTA's Avatar
mines 47MPH
Old 03-26-2008, 09:47 AM
DrkPhx's Avatar
Originally Posted by 99DWPTA
mines 47MPH
What converter and at what TPS %?
Old 03-26-2008, 03:24 PM
00cls1camaross's Avatar
under the lightest throttle, i asked my tuner to program 3rd at 28 and 4th at 33
