4l60E vs 4l65E?
CMON!!!!! I know someone knows this.... i just need a quick fix for now until i have the money to get a really nice tranny..... my dad knows someone with a wrecked tahoe and he was going to sell the transmission for 200 dollars nothing wrong with it and it has 90000......so if it fits.....and works fine.... with little modification... then good.....then i will be able to drive it and save for something good....but for now......i need a quick fix
The 4L60E in a tahoe or surburban are the same as the ones in a trans am or camaro. The only cars that carry a 4L65E are The 6.0 trucks like the Denali, Escalade and Hummers. The main difference on a 4l65e and a 4l60e are that the 4l65e has 5 pinion front and rear planets, and the 3-4 frictions have 7 and kolene steels on the 4l65e and 6 frictions on the 4l60e. The 4l65e was designed to be stronger, but a 4l60e built right can hold up to a lot of power.
The trans off the tahoe will work if it has the right input shaft.(some tahoes and surbubans used the lt1 input shaft and converter instead of the ls1. I think the started using the ls1 input shaft on 2003-on )
