FMVB on street?
Old 03-30-2008, 11:03 AM
blk99camaro's Avatar
Default FMVB on street?
I am pondering changing out my T56, to a 4L80E, It looks as if it will be rather expensive to have it as a "full" auto(conversion harness, controllers and such) Not to mention that I would not mind being able to shift the car myself. My car is a weekend warrior/day or two a week ride to work. The car already has a spooled 9". How are the shifts on a FMVB, my only concern is chirping the tires when just normal driving around town, the spool gets my car enough attention. And how does launching at the track go with the FMVB? Do you just stall it up like a normal auto? The car sees ALOT of track time(nearly every weekend).
Also, I have the UMI TM TA/ w saftey loop, can I make this work with the 4l80E?
What are my options if I went "Full auto"? Thanks for the help!
Jon
Old 03-30-2008, 11:22 AM
LS1Tech Sponsor
performabuilt's Avatar
We have several customers running the FMVB on the street andall seem very happy with it. Presure control can be hanlded by a vaccume modulator. So no the part throttle shifts do not have to be to agressive in normal driving . If you program the PCM and add the wiring harness you can even allow the PCM to control lockup for you.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-30-2008, 11:30 AM
Do I need an A4 engine harness and PCM to do this? Or is there an adapter for my M6 harness?
Old 03-30-2008, 11:33 AM
LS1Tech Sponsor
well if you want the PCM to control lockup you would need the A4 harness
__________________
Call 888-744-6542
Old 03-30-2008, 11:35 AM
Otherwise lockup is controlled by me, with a switch when I put in into OD, am I correct?
Old 03-30-2008, 11:39 AM
Also, Curently I have 4.10's, I would have to chamge to 3.42's or something correct?
LS1Tech Sponsor
Thats correct on the switch
And not really on the gears, Some like the A4 with gears that low
__________________
Call 888-744-6542
Old 03-30-2008, 11:53 AM
Does anyone have an in car video with a FMVB? i'd like to see how it seems as far as the shifts go. Also how will the react with the spool, do you think there will be any problems? is there a life expectancy on a properly shifted FMVB? My thing now is that the T56 is going to be ALOT more expensive to keep rolling down the street/strip in the long run.
Old 03-30-2008, 12:38 PM
UMI Performance's Avatar
Yep this will work just fine with out any issues. Hope that helps!
Ryan
Old 03-30-2008, 03:52 PM
Any Idea what RPM's would be like in OD Locked, with 4.10's@70?
Old 03-31-2008, 04:28 PM
STOCK12SECZ's Avatar
Can you give anymore info on the switch and how to lock up the converter manually? (4l60E ) Thanks
Old 03-31-2008, 04:59 PM
RICEETER's Avatar
i have the fmvb 4l60e and love it. with stock 3.23's @ 70mph, in lock-up, its around 2000 rpms. i would say no more than 2400-2500 with 4.10's
Old 03-31-2008, 05:46 PM
Do you have any videos(in car) with driving normally with the FMVB, and romping on it? If so can you post them for me?
Old 04-01-2008, 08:32 AM
RICEETER's Avatar
no i dont, sorry. but i'll be more than welcome to answer any questions you may have. it drives just like you were manually shifting your everyday auto transmission, only the shifts are instant. they are firm but not brutul
Old 04-01-2008, 08:41 AM
pddye's Avatar
I was looking into forward and reverse and I really like the reverse I have. I was worried on quick shifts I could accidentally put it into neutral on my 2-3 shift if I was to bump it to hard (using a th400 but this would be the same on your 3rd - overdrive in the 4l80). Also the reverse manual valvebody just seem more natural to me. It just seems right coming out of neutral and putting it right into first with a progression to 3rd being all the way back, instead of putting it thru all the gears before finding first then bumping it back thru them. That's just my opinion tho.
Old 04-01-2008, 08:43 AM
How about down shifts? I assume since the shifts are nearly insantaneous you cant just put it into neutral and coast? Do you drive yours on the street often? Can you adjust the shift firmness for say street, spirited, and strip?
Old 04-01-2008, 08:46 AM
I think the RMVB would be more natural for me as well, do they make a 4L80E with RMVB? I dont think I have seen one advertised
Old 04-01-2008, 08:48 AM
pddye's Avatar
I'm not to sure about it. I just had one in my th350 and also now my th400 so I just assumed they would have since they had the FMVB. It would be a good question for the sponsors which I'm sure will chime in here soon.
Old 04-01-2008, 04:32 PM
RICEETER's Avatar
Rossler has a rmvb 4L80. im not sure who else has one. Rossler also happens to have the cheapest 80e i've found and builds a hell of a product to boot.
Old 04-02-2008, 12:53 PM
I talked to Rossler's this morning, they DO NOT offer a RMVB for the 80E, they do offer a trans brake though I cant remember the mans name but he spent 30 mins on the phone answering all my questions and explaining different thing, and they have great prices to boot!
