cruise control
idk what is electronically controlled on your car or not, but i do think on LS1 f-bodies with an automatic the cruise control is electronic. someone correct me if i'm wrong, i know my 02 camaro is
Is that what you're talking about because you didn't say what car u did this on and i guessed it was that WS6 in the picture?
i don't have a clue how to fix it, someone else help him please
If you get the speedo to work the cruise will work again. I did the abs trick to get my speedo to work again and it also got the cruise to work. Just jump the two wires off an abs sensor or get the vss to work with a different setup off the trans.
