Supermatic 4L85-E
Old 04-25-2008, 12:06 PM
ShevrolayZ28's Avatar
Default Supermatic 4L85-E
From GM Performance parts. Anyone out there running one of these? And how about the GM controller?
They say it can handle the "mighty ZZ572/720" crate engine.
It comes with a production torque converter (approximately 1,800 - 2,000 rpm stall speed). Price is around $4000 with converter and GM controller.
Old 04-26-2008, 11:55 AM
Nobody? I thought there'd some interest.
Some info:
19154550 GM Performance Parts SuperMatic 4L85-E Transmission
Hydr-Matic 4L85-E Four-Speed Automatic Transmission. GM Performance Parts is pleased ot announce the new SuperMatic line of Performance transmissions. It is compatible with all GM Performance Parts Crate engines and was specifically validatedd with the mighty ZZ572/720. This transmission is assembled with all new parts, several upgraded internal components, and a revised valvebody. This transmission is supplied with a production torque converter (approximately 1,800 - 2,000 rpm stall speed), and requires the GMPP Transmission Controller P/N 12497316 (sold separately).
Supported by GM performance Parts standard limited warranty of 12 months/12,000 miles
Transmission Controller 12497316 Description
Includes wiring harness, controller, software and lap-top hook-up. Allows the use of electronically controlled transmissions in early model vehicles. Fully programmable for upshift, downshift, part throttle and wide-open shifts and shift firmness. Comes pre-programmed, just enter your rear tire diameter and rear axle ratio and go, or create your own custom shift characteristics. Originally developed by GM Racing for off road truck racing. The controller has the ability to record and graph drag race data like time, speed, shift point, engine rpm and more. Requires a throttle position sensor on carbureted applications, see instruction manual for specific parts required.
Old 04-26-2008, 08:11 PM
SPDMETL's Avatar
I don't have one, but have you looked at the Gearstar units ? 8K ! I don't think that includes the controller, either
Old 05-02-2008, 01:51 PM
Yes, I've seen the Gearstars. At those prices I would imagine they are made with precious metals lol.
Old 05-03-2008, 10:24 PM
SPDMETL's Avatar
I wonder if anybody has broken one ? For that much it had better outlast nuclear waste !
Quick Reply: Supermatic 4L85-E
