New torque converter install possibly ruined idle...
Old 04-26-2008, 11:08 PM
epox4life's Avatar
Default New torque converter install possibly ruined idle...
So I just had a new TCI SSF 3500 converter installed along with a BBK intake manifold. The car runs great once warm, and pulls much harder then before the install. There is a little surgeing here and there but the car never dies at lights or anything.
The issue lies with COLD starts, in the morning when I go to start the car it will either have very bad surging or just die. But if I give it a little bit of gas to hold it around 1k rpm for say 10 seconds or so the car will begin to idle like normal.
I tried adjusting the screw on the throttle body which did help a little but it keeps throwing an error code "unexpected higher idle speed" or something close to that.
Did something go wrong with the install? or do I just need a tune?
Old 04-26-2008, 11:10 PM
LS1Tech Sponsor
performabuilt's Avatar
You need a tune
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-26-2008, 11:14 PM
epox4life's Avatar
Originally Posted by performabuilt
You need a tune
Someone suggested I might have a bad spark plug or wire. But i'd think I would have got a misfire code at one point if that were the case. So I think your right a tune sounds like a more likely solution.
Could an unbalanced converter cause this? I noticed a little shakeing between 1-2k rpm but it's probably just the exhaust, cause everything smooths out past that.
Old 04-26-2008, 11:18 PM
LS1Tech Sponsor
Sounds like and exhaust resonate ,
__________________
Call 888-744-6542
Old 04-26-2008, 11:28 PM
epox4life's Avatar
Will the tuner know what needs to be done when I explain the situation to him. Or is there something I need to tell him to change?
Old 04-26-2008, 11:56 PM
LS1Tech Sponsor
If he is good he will know what to do
__________________
Call 888-744-6542
Old 04-27-2008, 04:51 PM
epox4life's Avatar
I think I found the source of the problem there is a hose that goes into the side of the intake manifold that was just slid on and didn't have a clamp or anything holding it on. I noticed that it came on and off very easy and would cause the engine to surge so I used a worm clamp to hold it on there tight and now i'm waiting for the engine to get cold to see if this fixes it.
Old 04-28-2008, 10:18 AM
epox4life's Avatar
ok this didn't solve the cold start issue... looks like I need a tune.
Old 04-28-2008, 11:05 AM
Moderator
jimmyblue's Avatar
Yes, the lower "flywheel" mass of the small converter
does not hide the crappiness of the idle tune as well
as before. So it (tune) needs to be tighter.
Old 04-28-2008, 08:31 PM
ponyeater01LS1's Avatar
anything over a stock converter should be tuned you get more out of it for one
Old 04-28-2008, 10:46 PM
epox4life's Avatar
I tuned what I could with my hypertech power programmer III which isn't much just the shift points, and shift firmness since I don't have a shift kit. Both which helped somewhat. Converter locks up around 46mph which is ok for me. But the cold start in the mornings is getting annoying. It's just weird cause once it's warm it has never had any problems dying at stop lights or anything.
Old 04-30-2009, 01:01 PM
J-Bru-Ha Z-28's Avatar
I have the same issue...at a stop light it will bounce between 500-1000 RPM while in gear, if I throw it in Neutral it is just fine. Every once and a while it will stumble real bad after sitting at a light for a long time...it also seems to happen more often when the engine is cold, I have a Vig. 3200 stall with the hypertech tuner as well see my sig. I just put some LT's with an ORY on while deleting the AIR and EGR as well and it has made everything worse almost to the point where it will stall out...So the overall opinion is that a tune will help both of us out???
Old 04-30-2009, 01:52 PM
LS1Tech Sponsor
Yep a tune will fix you up
__________________
Call 888-744-6542
Old 05-18-2009, 01:18 PM
Turns out the majority of my idle issues were caused by a vacuum leak that developed in the short 2-3" hose connecting the PCV valve to the throttle body. I still get a slight idle variation but not nearly as bad as before...I still need to get a tune to smooth that out...
Quick Reply: New torque converter install possibly ruined idle...
