Converter Lockup/Tranny Readings from HPTuners?
Old 04-30-2008, 12:05 PM
nahasapeemapetalon's Avatar
Default Converter Lockup/Tranny Readings from HPTuners?
What will hptuners scanner give you for tranny readings. I havent found much on there for that...
Will it tell me if the torque converter is locking up or locked up?
What gear its in etc....?
Or do i just have to feel it lockup?
Old 05-01-2008, 09:25 AM
Moderator
jimmyblue's Avatar
There is TCC_Mode, it doesn't export or plot because
it is a text string like -3- or Unlocked but you can view
it in the table at least. -3- means "I'm going to sit here
and pout, misfires, wah". Trans Current Gear, there are
some other PIDs like force motor current and commanded
line pressure that are of use. A lot of things reference
Delivered Torque - Trans as their index.
Old 05-02-2008, 12:45 AM
petercln's Avatar
it will also give you trans input rpm and output rpm, converter rpm slipage. trans temp in degress and volts.
