Are my 60's on par for my Stall?
Old 05-03-2008, 09:57 AM
StealthFormula's Avatar
Default Are my 60's on par for my Stall?
I went to the track a few weeks ago for the first time with the Stall and was running consistent 1.69 60's launching off idle. At the time the car was running a Yank SS3600, 3.73's, 255 ET Streets, Non Adj. Torque Arm, Panhard, Subframes, and LCA's, Lowering Springs, 330rwhp, at a 3650# race weight. I did lower the car and never planned to hence the non-adj. suspension setup but I am planning to add some LCA Relocation Brackets to get back some of the lost suspension geometry. Anyways, am I on target for what you would expect from a Yank SS3600 and the rest of the car's setup or do I need to make some adjustments?
Old 05-09-2008, 05:31 PM
01ssreda4's Avatar
sound pretty good to me...
Old 05-10-2008, 10:06 PM
Ragtop 99's Avatar
That's right on target for your power and weight.
Old 05-11-2008, 10:22 AM
Z-RATED94's Avatar
Personally I think it should be slighty lower. At least between 1.60 and 1.65. with your set-up.
Old 05-11-2008, 10:27 AM
BrianC98Z28's Avatar
should be a lil lower, the non adj tq arm and lowering springs are killing you, could be in the 1.5s with a dead hook and the suspension dialed in.
Old 05-11-2008, 01:07 PM
Kenny H's Avatar
An LT1 should be 60 footing a tad better than that.
Old 05-11-2008, 01:41 PM
CamaroRacing12's Avatar
i kno if i get a 1.69 this year i will be very happy
but i agree with ur mods it should be around 1.65, few more trips to the track u will prolly get it
